1981 Malibu 2 door front shock replacement
Toolman78
19
8
I am going to replace the front shocks on my 81 2 door Malibu when it’s home from storage. The top bolts don’t turn. Any tips to get them off? Also it is a v6 car with a 350 swap. Should I buy the v8 version of shocks or any recommendations? Thanks. Tim
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
The shocks are the same. The difference is whether you go performance or lowered. The nut usually rusts itself to the shock tip. what is hard to see is that there is an oval shape to the tip. You can find a professional tool (like a socket) cut for that shape (Lisle is one brand). you can also take a cutoff wheel and grind a hex into it for a box end wrench or socket. Use penetrating oil on that nut and on the bolt/clip nut combos in the control arm. The clip nuts are replaceable if you mangle one of them.
Toolman78
19
8
Thanks. I’ll try getting the tool
565bbchevy
9,614
12,683
Michigan
If you are not saving the shocks use a deep well socket on a long 3/8" extension and move it back and forth a couple times and it breaks off the stud below the nut.
