jrm81bu said:Yes and no. It can be made to fit with a bellhousing adapter, custom crossmember and a shortened driveshaft for starters. But no it really isn't a bolt in replacement. You would be better of looking for a 2004r that will go in with less complication.
pontiacgp said:if your building an engine to have some extra hp you'll be disappointed with the 700 r4....it has a lower first gear than a 200 4r but it hits a wall when it drops in 2nd...the 200 4r has much better gear ratios and they can built to withstand alot of HP
Camshaft said:jrm81bu said:Yes and no. It can be made to fit with a bellhousing adapter, custom crossmember and a shortened driveshaft for starters. But no it really isn't a bolt in replacement. You would be better of looking for a 2004r that will go in with less complication.
I already planned on a new cfrossmember & driveshaft - I'm also swapping the rearend to an 8.5 over the winter. While a 200R4 will go in with less trouble, how will it stand up behind the 403 I plan on building for it?
custom442 said:I vote a 3 speed unless you do a lot of highway driving. IMO a th350 has the best gear ratios of all of them
pontiacgp said:you might want to have it upgraded so it'll be more than capable of handling the hp of your engine....
I found this and thought you might be able to relate to it..
http://www.youtube.com/watch?v=DbCI68eSNsA
:lol:
