'83-'84 Monte SS's had 3.42's.
'85-'88 Monte SS's had 3.73's.
Keep your eyes peeled at the bone yard...
if im not mistaken its a th200megaladon6 said:driveability can also depend on what trans. do you have a th350, 200-4r, or th200?
Bonnewagon said:Before buying, be SURE it's a posi rear, and be sure it's the ratio you want. A code will be stamped on the front of the pass side of the axle tube. You will need to know the codes for the ratio you seek and factory manuals are about the only place that shows them. For example, an 83' Pontiac "G" series wagon with a 3:23 posi would be 2BU. Best way is to open the cover and look on the ring gear, it will have 2 numbers, one for the ring gear and one for the pinion. Divide the ring gear by the pinion to get your ratio. The posi clutches will be obvious. I was at an indoor swap meet at in Allentown PA and a guy swore he was selling a 3:23 posi rear. I had a socket and I opened it up- lo and behold it was a 2:41 non posi. So buyer beware!
