I do plan to keep this as a 2-bbl - since I plan to keep the tame 2.41 gears, and want this as a smooth, relatively economical cruiser, rather than a brute (at which point I'd probably just swap to a 350 or 400). If I can tweak a little extra torque out of it, so much the better.
I think there's only 2 or 3 other vacuum lines that have sizes that are not 5/32" that I have to replace. Hey, I had a spool of 5/32, but I didn't have anything else! They actually look to be in decent shape, but I want to just get all the rubber hoses replaced. One's 3/16, one's 1/4 inch, and whatever the size is of the PCV line, etc. Gotta get those taken care of.
I only did a "quick and dirty" carb base gasket check by simply bearing my weight down on the air-cleaner assembly as the car was running. It made no difference, but I don't think that's exactly a good way to check the carb base gasket! LOL
Now that i know where all the vacuum lines run, I might try disconnecting them ALL, putting vacuum caps on, and seeing what happens. May try that either before or after doing the following:
- Replace remaining odd-sized vacuum lines, and PCV valve
- Fuel pump
- Plugs, wires, cap, rotor (check advance springs while I'm at it!)
- Pray that all the weird vacuum delay valves and thermal vacuum valves still work correctly!
If that doesn't work, then, well, I suppose I have to blame the carb. Dang shame, too, seeing as everything off-idle runs beautifully, and the previous owner said that the idle issues started very abruptly, sometime in the fall of last year (I bought it in December)
