The other day, I took the car for a ride to check out the TCI lock up that I had recently hooked up the vacuum and wiring on. Up until this point, the trans had acted fairly predictable, shifted a bit early, but was tame enough. Now, it wants to go into overdrive almost immediatly after hitting 3rd gear....and it wants to stay there. Also, when I manually shift down, sometimes nothing happens at all! And, towards the end of my ride, the car wouldnt down shift by itself as I came up to a stop sign....like it wanted to keep going...almost stalled the motor. My tv cable is hooked up, but the adjustment is sketchy, because the cable wont reach the carb, so I made an extension to go between the carb lever and the cable. It seems tight enough and looks to be functioning properly, but these cables have always been a sore spot for me, never seeming to be in the right spot, especially on my T-bird. Do ya think I might need a new cable? or could it just be an adjustment problem?....any replies are welcome. If the trans is toast, Ive got a th350 that I can install, but I was hoping for better milage with the 2004r. Thanks!
