I recently started to drive and shake down an 83 wagon i bought awhile ago. Finally got it raod ready and have been trying to rack up some miles to see what still needs attention. it has a 350 300horse crate motor and what i believe is a stock 2004r with 4.10's in the rear. my issue is with the 2004r. last few days it has been hesitating to down shift from 2nd to first and almost stalls the cars before finally down shifting. milage of trans is unknown aswell as what fluid is in it . been doing some research and it is all over the place some people like dextron 3.some dextron 6 . some say do not use synthetic. Type f fluid seems to be popular also.
setup now is edelbrock carb,no relocation bracket on carb for tv. just has stud for tv cable bolted to arm.(all the brackets severly misalighn the cable.)
stock gm montecarlo ss throttle/tv bracket
stock trans unkown milage
believe stock monte ss converter
lockup is currently controlled via flip switch with pressure switch on outside of case.
