Hey all,
Is it possible to control the torque converter lockup on a 200R4 via a switch? Is there a fuse in the fuse box for the lockup - if not, where could I find the wire? I'm pretty sure it's electronically controlled - right?
Long story short, my car just about stalls out in 4th gear when the torque converter locks up because it goes into 4th gear so early. I've been having to leave the car in 3rd and then manually shift into 4th after the car is going fast enough to where it runs right. I don't want to continue doing this though because it's an automatic, not a manual haha. I also don't have the facilities to adjust the shift points. I'd rather be able to initiate the lock up after a certain speed.
From a cold start the car runs in 4th fine, it's just after it warms up and the torque converter locks up in 4th at 28mph that it chugs and shakes and rattles because it's at about 100 rpm lmao
