20mm wheel spacers, 7/16 thread: help me find?
brrian
273
291
51
Pittsburgh, PA
I'm having no luck finding 20mm (or 3/4") hub-centric wheel spacers, 4.75" bolt pattern both ways, with 7/16 threads. I can find 12x1.5mm threads, or can find 7/16" in a 1" spacer, which is a bit too thick. Anybody know of a place I can get this exact combination?
If I can't find this I'll go with 12x1.5mm threads but for OCD reasons I guess, I'd like to keep everything 7/16".
Thanks...
Just spitballing here, but could you purchase the 1" variants and machine away material from the backside? It wouldn't negatively affect anything I can think of so long as it's milled true. Then you don't have to compromise.
2 possible reason you can not buy.
The ones in the pic from 81cutlass, let's call them adaptors, bolt to your car before the wheel. That can not be so thin that the nut sticks out. Must be thicker than nut.
A spacer changes the load further away from the base. Maybe in this case too far. These are typically pretty thin.
You can get these in 3/4" thick with 7/16" studs
They can also build you custom hub centric adapters
