Thanks again, I'll head over to the junkyard sometime soon and grab one of those stickers, if they have an '83. I'll get some vacuum line like you suggested, it's cheap and can only help, so why not :lol:
The way you told me to hook up the damper door was how it originally hooked up when I got it, but the guy switched it around for some reason.
Also, when following around all the lines by the carb, I found a green connector that isn't hooked up to anything, and I can't find anything it would hook up to.
It has two bluish wires runnung into it, and its located pretty much directly in front of the carb. The wires come out of the ribbed plastic stuff used to route a bunch of wires together. Does anyone know what this?
