youngwhip I ee your locaton is Bishopville, SC.
I drove down and picked my 330 up from a guy in Rock Hill, SC.
youngwhip said:ok everyone i got the 330 ods today and im so lost...i have no idea where to start from. the motor is in great condition so i just tryin to put it in now with no work done to it. should i just dope it in with the trany bolt on or what???
youngwhip said:well the last time it was running was a year ago..it was sitting in the shop ever since.i was just wounder if my 307 Exhaust Manifolds will fit on the 330 motor and the distributor . but thanks for the other info as well i will do that also..
dan2286 said:youngwhip said:well the last time it was running was a year ago..it was sitting in the shop ever since.i was just wounder if my 307 Exhaust Manifolds will fit on the 330 motor and the distributor . but thanks for the other info as well i will do that also..
The 307 manifolds do fit. Are you planning on running this on the computer? If not, you will need a non computer controlled HEI Olds distributor.
youngwhip said:dan2286 said:youngwhip said:well the last time it was running was a year ago..it was sitting in the shop ever since.i was just wounder if my 307 Exhaust Manifolds will fit on the 330 motor and the distributor . but thanks for the other info as well i will do that also..
yes i plan on using everything off the 307 for now..so yes i plan on running it on the computer, is that a bad thing?? and i just try to pull distributor out but it wouldnt come out. do u know why?
