most 305 heads had 56cc to 58cc chambers, which is similar to L98 heads found in late 80s corvettes.
when used with a traditional factory dished piston, the 58cc chambers can offer anywhere from 8.7 to 9.5:1 compression
it's on the high side, but plenty safe for pump gas. If you plan to use an aggressive cam, you may need excessive timing advance, which will cause detonation with that kinda compression. You would need 91 octane there.
keep the cam mild, you can use high lift, mild duration to have good street manners. You can run 87octane, and make good torque without detonation
