72 Block with 42k
Just got it back from the machine shop. Boiled, New Cam Bearings and Freeze Plugs
and now its time to build it, ive got a decent list so far, im open to any and all suggestions as this
is my first performance build.
Im looking to get 350-400 horse out of the motor
So far ive got,
Edelbrock RPM Intake
Hedman 1 5/8 primary long tubes
What im thinking...
Pistons : Mondello Forged Alum Flat Tops
http://www.mondellotwister.com/PisPinRingBrng.htm
P/N - 2020
With my stock 72 7a heads, 64 cc's these pistons will be about 10.3:1 CR
Would i need valve relief pistons if im going to run a 515/533 or 505/505 lift cam?
Cam : Comp Hyd Roller
http://www.compperformancegroupstores.c ... gory_Code=
or
Will the 515/533 lift cam be to much for the motor?
* with the associated locks, retainers and springs
Lifters :
Rockers : Should i go stud or pedestal mount?
1.6 Scorpion Roller
http://www.flatlanderracing.com/scorpio ... .html#olds
P/N SCP1089
or
Harland Sharp
http://www.harlandsharp.com/amc_jeep_olds.htm
Im sure im forgetting something, THanks in advance for feed back!
So far ive got,
What im thinking...
P/N - 2020
or
Lifters :
1.6 Scorpion Roller
P/N SCP1089
or
Harland Sharp
