383 est horsepower
Hello im new to the forum and im building an 87 regal. I am building a 383 chevy stoker motor it is bore .30 has dart 200 iron eagle heads,1.6 rockers,crane gm 847 hyd. roller cam 540/550,dual plane dart intake,and holley hp 750.My compression is 10.3. I have an th350 with an 10inch 3200 stall.Im gonna problaly put 3.73 gears in the car.Any suggested hp or et with good traction.
CHRIS.O
1,432
36
MI
My guess is 450-470 crank hp.
chevy2480
1,245
6
38
williamstown nj 08094
JBreu
2,167
20
38
Livonia, New York
I'd say somewhere in the neighborhood of 500 crank hp...... 12.60 1/4 :)
chevy2480
1,245
6
38
racereg1976 said:
I will be running a holley black pump with regulator do you fellas think that enough fuel.
You will be fine you can even go with a blue. I have a buddy running 11.70's on a red. I am going 11.18 on a blue.
Jan 1, 2012
Thank i thought it might i had almost the same build in my old s10 and detonated the motor by either not having enough octane or not enough fuel that build had 11.1cr with 64cc iron heads plus i had a red pump with a regulator a no no!
CHRIS.O
1,432
36
MI
Even with the 10.3 compression ratio make sure you have a good quench area. As close as .040 as you can get with save piston to valve clearance and pump gas should not be a problem. You don't want to detonate another apart.
