4 DR-2 DR FRAME
MAN_N_BLACK
15
39
hartley iowa
I was wandering if the frames were the same between a 4 dr cutlass and a buick regal
No i dont think there the same, but i could be wrong. Welcome to the forum!
The difference would be in the front frame horns, wheelbase is the same. Wagons and El Camino are different.
Some are identical, some are not...
You need to measure the frame horns (distance from the core support mount to bumper shock mount).
If they're different, it's not hard to lengthen/shorten them (you'll need a welder), or if you get lucky sometimes you can just compress the bumper shock a bit if they need to be shorter.
