7.625 rear end swap
4
Hey All,
So I'm about to pick up a 3.73 posi 7.625 out of an 85 monte Carlo ss and wanted to know if it would be a direct bolt in, in place of the factory 7.5. Thanks.
I'm thinking both should be 7.5. If you are talking about the whole housing then they should be the same. Depending on your current gear you will need to make a change to the speedo gear in the transmission to correct the speed.
x2...Should be a direct swap. Just have to change the speedo gear.
