DrRansom442 said:the lockup really isn't quote a gear thing unquote .... it's the converter that is locking up and yes this usually occurs in 4th gear cruising down the highway. Several companies make lockup kits for the 200-4r/700-r4. B&M, TCI, Painless. Just look on Summt. They'll probably have 5 or 6 to choose from. A TCC lock up can be as simple as a toggle switch to more complex devices that lockup as soon as it shifts to 4th and unlocks on downshift ... to some that have a built in delay. Honestly, you don't even have to hook up the TCC, but you'll have better highway manners and mileage. Installing into a G-body. The negatives are ... well a G-body was never designed for the 700, so custom crossmember, tailshaft and size (I've heard a few people say some massaging of the transmission tunnel with a hammer is needed (2nd hand info). They weigh more and aren't gearred like the 200-4r (as previously stated) .... where as a 200-4r uses the same driveshaft as your th350 and a factory crossmember is easy to find. Not really trying to sway you away (there will be no revisiting the SBC/SBO thing), if you got a deal great - go that way and be happy with it.
DrRansom, this is all cool info I didn't know about the 2004R,
too bad they're not as common up here in Canada Land, or atleast not around my parts...
What do you know about the 200R4... I've heard it's a garbage transmission... true?
