NOT anymore.
Threw on a set of 706 heads after a valve grind and spring swap. Found the damage to the cam - WOW - cam was contacted by 5 rods when the timing chain stretched and went kaflooey. Obviously the cam went bye bye. Throwing out the old 230/226 .621/.621 and put in a 234/234 with the same lift with a 115LSA on a 111ICL. The extra .8 of compression with the bigger cam seems to operate at about the same at idle. Also threw in a pump and set of bearings. The concern of reused parts were the lifters. They too a beating, but seem fine but keeping an eye (ear) on them.
Hopefully a couple of test hits this weekend now that it has stopped snowing in May. I'll see if I can get the GoPro working 🙂🙂
