80' Regal Resto
Took the week off of work and decided to work on the regal.
Not doing to bad, gotta remove the rear end and the front end assembly then its back to blasting the frame
mhsmonte said:
Whats your blasting setup?
A 40lb portable from northerntool and black diamond abrasive 20/40grit (suggest using a softer grade this grade kinda roughs it up pretty good) working on getting a bigger air tank for longer blasting. Also have a soda blaster to but ima use that for more of the bodywork because its softer
Im getting ready to strip my frame... Thanks for the info!
No problem
Slow pacing lately been really busy with school and work leaving no time for the G. But here is a few updates 😀
