Price is for everything.
$1300 for everything.
This dash was redone a couple of years ago for my restoration project. The rear metal bracket was sanded down, primed and painted. I've decided to go a different direction. The lower kick panel (with defrost) was damaged but I do have a better one in a different color that's included. I still used the original one because it still bolted up to the dash without an issue. The Buick Regal applique above the glove compartment lights up. All that's needed is a ground and positive. It originally connected to the dash lights and climate control back light. The original upper speaker cover was cracked so l started vinyl wrapping it but stopped when I decided to change the interior color. The defrost section on it needs finishing. The dash could use a wipe down. This is an original dash so it may have a few blemishes but very unnoticeable. I removed my glove compartment key cylinder because I will need it. I also have the kick panels, head liner and lower a piller trims and a set of upper door panels included. (See last pictures)
Natchez Ms
Natchez Ms
