I am looking into doing some work on my a/c system. it currently has the r4 radial compressor and had r12 in it. compressor is on the driver side like most g bodies.
where do I get a/c lines if I wanted to swap out to a sanden a/c compressor like all the aftermarket aluminum brackets are designed for?
what do I need to retrofit system for use with 134a?
how about r12a? is this a direct r12 replacement?
lots of info floating around that conflicts.
