81 regal resto mod lowrider
Good looking build bro! Can't wait to see it come along! What kinda set up you running for your juice? Looks like some fresh spokes and 155/80 13s on her! What kinda wheel you go with? Lastly, curious why you opted for a coil under set up vs coil over in the rear, especially if you plan to 3 wheel. Really excited to have another fellow lowrider on here!
Reactions: fleming442
You put a lot of work into that car. It is neat seeing what it takes to build a car like that.
thank you yea that’s what I do I build lowriders I do suspension And hydraulics restore cars
I agree. We definitely need more lowrider build pics.
So, what made the jumps in preferred body styles? My whitebread @$$ only sees the late 40-early 50s, early 60s, the the G body jump.... what gives?
what do you mean jumps in years or the hydraulics
Good looking car and some excellent looking fab work. Keep posting as you get along with it.
thank you I will
On another note having some motor issues any body have a 400 carb edelbrock or Holley or should I just go Holley sniper efi
And I got a leak from my oil pump cover feels like it’s blowing out the side only on one bolt I bought a original gm one on and it leaked I put another gasket sealed it And silicone on bolts still leaked bought a new Melling one put it on an it’s still leaking Any suggestions
Thank you. 2 pumps 6 batteries piston Running 5-20s on 88 spoke Dayton’s and I’m not a big fan of coil over To much nosie only running a 12 in the rear Any thing bigger you have to go coil over and I don’t like that big high lock up stuff growing up in this cars gotta sit on the floor to be a lowrider don’t get me wrong it’s cool But you gotta be low I can still 3 IT would probably sit on 3 if I took the sway bar off I’ll post picks of the setup maybe tomorrow working up music right now gotta put it back together
Reactions: H33ZY
Very sharp looking, can't wait to see this all together
Very cool bro! I have a 2 pump 6 battery set up, #9 gears 36 volts to each pump running 8s and 12s. Sitting on triple stamped 72 spoke Dayton's with Premium Sportway 520s. I did a coil over with powerballs and then sleeved my cylinders where they come through the frame and the body. 1.5 tons in the rear and 3 tons up front with 1" extended arms. Super quite ride and great articulation with my adjustable uppers, lowers and axle pivot bushings. I cant get standing 3s unless I have someone in my back seat...just a tad short on weight for me. I can hit and ride 3s all day with vehicle momentum. However due to cost of 520s and the Ds...I rarely 3 wheel anymore lol. Cant wait to see your trunk and this beast finished!
