Uncletruck said:In 1988 all G bodies made since introduction in '78 were recalled for the rear brake cylinder clips coming loose. The cylinder would then start to move, and wear out the mounting hole in the backing plate. This would eventually cause the cylinder to not line up with the engaging spots on the shoes and blow out. The new type cylinders will straddle around the upper spring mounting pin so the cylinder shouldn't move. Sometimes the backing plate holes are so worn out though you have to replace the plates. (No fun at all.) It's not uncommon to run in to G bodies that did not have the recall work done, just something to be aware of.
-UT-
thanks for the info, i will def keep that in the back of my mind, as far as I could tell the back plate were in very good condition and yes the new cylinders seemed to clip in well.
