whats the best method to use for removing upper and lower ball joints and control arm bushings? my 1st time removing these so i need help.. thanks
Blake442 said:Upper ball joints you should be able to grind off the rivets that hold them in or even use an air chisel.
The lowers and the bushings are a bit trickey, and I just took mine to the machine shop down the road from work and had them pressed out and the new ones pressed in. There's other ways to get them out, but I'd rather not dick around with that stuff. It's worth it to pay somebody to do it for me.
