83 c utlass y code egr
jim83
Mar 21, 2018
60
23
8
76
Need some ideas- car has 60k on it from new. Fails high speed nox test all others are fine. Do olds y code motors have a history of egr passages coking up and restricting flow?
Thoughts or actual experiances please. Also what is the lesser of the evels for an egr valve- Delco or??
thanks!!!
Yes the passages build up with carbon, stiff wire to clean them out. Go for an AC Delco or whatever you get without too much hassle.
So in effect if passenges get coked/ carboned up the lack of flow will cause high nox?
This car has been a struggle to smog. Carb ovehauled off car, replaced tps , o2 sensor etc.
Will try cleaning passagess & if necessary a new egr. Thanks!
