83 Hurst carpet
2nd83H/O
8
Does anyone no what was the color of the carpet in an 83 Hurst with the sandgrey interior.I can't tell if it's gray , med.gray sandstone etc.. Thanks
ACC has the one you want for $215 big ones :shock: but it's the correct color.
As for the heal pad I'm not sure if its the later 86-88 pattern or if they are using the 81-85 pattern.
I suspect it's correct considering the 87 442 carpet is only $125.
Item: 2316-83
Color: 7623 M.SAND GR/NEUTR
http://www.accmats.com
Add $67.50 for the correct mass backing. 😀
