83 Hurst/Olds Carb and computer command control?
hajnovak
126
5
scranton Pa
Can anyone help me out with the correct Carb and computer to put back on my 83 Hurst. I want to get it back to factory original with the smog pump. Currently has a Holley 650 runs great but kinda want original. Thanks in advance for help , any and all is greatly appreciated. Mark
Yeah, you need an ECM from an 83 Hurst Olds! You'd also need a carb from an 83 Hurst Olds though you can use any CCC carb that came off an Olds 307 with 5A heads. You will also need an Olds CCC distributor, but they are not specific to any one year, so you can get one of those anywhere.
Aren't the vin 9 carbs calibrated richer? Just keep an eye out for the proper carb, be patient.
