83 Regal - Troubleshooting HVAC
Johnny O
n00b
Feb 8, 2025
47
Need some help fellas. Have a 1983 Regal.
Here's what I've got:
• Getting zero airflow from any vents, dash, defrost, floor on any setting.
• when I turn AC on I can hear the doors in the system opening and closing at the right time so I think vacuum lines are ok.
Checked the fuse, had a 25 which was blown, replaced it with 30 amp per spec. No airflow.
Ground on the blower motor looked useless as it wasn't grounded to metal.
• relocated ground to metal on engine bay sidewall. No change.
• changed out the resistor, no change.
• Changed out the relay, no change.
• replaced the blower motor, no change.
Im thinking the motor isn't actually getting power or the ground is bad??
Many times the connector in the wiring harness going to the power lead for the blower motor melts and needs to be replaced or bypassed.
