Sounds like a cool car!I have one of the offical cars from 83 indy put a 84 hot air turbo in it hard to start
car hard to start but once started and warmed up car starts easy not sure how or if there is a choke on the hot air turbo or what senses when engine is cold that mite need to be changed or adjustedWelcome to the family from another hot air draw through guy. We need a little more information on your problem to be able to help. O and we all love pictures!
dose not turn over hardIf your engine is a 84, then it is a fuel injection engine. I would look into a timing issue, fuel issue, mass air sensor. Does it turn over hard, or does it just not take off right away? If it is a 83 engine then it will have a carb and different likely problems. Have you asked on the TB forum?
dose not turn over har is a fuel injected eng and noIf your engine is a 84, then it is a fuel injection engine. I would look into a timing issue, fuel issue, mass air sensor. Does it turn over hard, or does it just not take off right away? If it is a 83 engine then it will have a carb and different likely problems. Have you asked on the TB forum?
