84 Hurst/Olds Lightning Rod Help
85Regal801
46
33
33
Hey guys I just won this 84 Hurst Olds on a raffle and it just got delivered, she’s definitely a project but one of my main concerns is when I put the left rod into OD it’ll shift into all the gears but it won’t go back up into N or R I have to fight with it, any ideas? Previous owner said the trans was recently rebuilt.
Check that VIN again. Looks like you got an 83 H/O with a sand gray interior. To which, sand gray was never an interior option for 84 H/O, regardless of what the early ordering information showed.
Sounds like a couple of possibilities- the push buttons aren't adjusted right on the shift cables to allow the buttons to be pressed down far enough to get it into reverse, or something else could be jamming them up. Without looking at it or observing the operation, it'd be tough to make the correct diagnosis. Whatever you do, don't force it, you'll break the little tabs on the bottom end of the shift detent release. Some of the detents you need to press the button down completely, others you can just depress it slightly.
When they operate correctly, Lightning Rods are cool AF. But when they're misadjusted, or broke, they're a huge PITA.
If you need shiny new black knobs, I got them.
88hurstolds rebuilds them. He may know what's going on with the issue without even looking at it. But send him a PM, he can help you out.
Pin is busted in the shifter and will require welding, I can rebuild and repair almost like new if needed.
