85 monte trnasmission line help
Daves85
Feb 21, 2009
59
New England
hey,
this may be a dumb question but i figured id get a good and quick answer here.
i have a stock 85 monte carlo (200-r4). one transmission line has a small hole in it. and im looking for the cheapest easiest way to fix it... my question is: would a stainless steel breaded line with the right fittings work?? ive seen stainless steel breaded lines that handle alot of heat and pressure.
i have the lines unhooked now.. its only jacked up on one side, and im not able to get the lines out in one piece.
thank you for the help. i want to get this car driving this season!!
They would work...YOu can also use brake lines as well...Even cheaper yet!!! 8)
the tanny line got damaged in a radiator swap.
thanks alot!!! looks like ill be pealing out again in no time!!
great lookn car BTW!
i found a website that has pre bent transmissions lines. inlinetube.com
i just ordered oem lines for 50$
Will they clear the headers? I have never had non cut/ rubber hose patched leaky cooler lines and would like to do something about it
