If slowly revved theres no bog or backfire. Starts up fine, idles good, full tune up, choke works, replaced bad vacuum break. Even tried a carb from a running motor. Still no change. The car idles perfect. If revved hard off wot it will back fire through the carb. Driving the car normal it has a tip in stumble. Timing is rock solid 15*. Could this be an egg problem? I've disconnected the vacuum hose and capped off with no change. Only thing I haven't changed is the 02 sensor. No ses lights.
