85' SS 383 stroker build and suspension upgrade
slow85SS
8
35
Ft. Lauderdale, FL
whats up, i figured I should start a thread on my current build. The car is a an 85 monte carlo ss with 59k miles. I bought it from the second owner at a local car meet (davie, FL). The car currently has a 4 bolt 350, and all necessary bolt on parts from the exhaust to the fuel system. The only parts that i will be transferring over to the new build will be the Barry Grant 280 fuel pump and Nitrous system. In regards to suspension, i have Bilstein shocks on all four corners, front and rear sways, and springs. The ride is very bouncy and is in need of an upgrade which is why i am looking at coilover/suspension upgrade from Ridetech and BMR(roughly 3 hours north from where i reside). I eventually want to upgrade the rear end to an 8.5in or a 9in ford as well as Disk brakes on all four corners. This will be a street car.
This is a general breakdown of the engine build
350 4 bolt fully machined and prepped by Redline Automotive in Davie, FL
Eagle crank and rods
Mahle forged piston
Moroso 6qt pan and pump/pick up
Dart SHP 200 64cc heads
performer RPM manifold
Holley 750 street HP
BG 280 electric pump/reg
N.O.S. 150 shot
Transmission
2004R
TCI 2800
CKperformance shift kit
CKperformance street/strip master rebuild
Here are a few pics of the car in its current state
update as of 12/24/2015, Block has been decked, bored, and mains honed. Cylinders need to be honed and the the block will be ready for the rotating assembly. Merry Christmas folks.
hey hows it going, when i dropped my block off over at Redline rich mentioned he just did a 383 that was going into a Monte, looks like you were the guy, we have a similar build minus the brand names lol. its already been a month since I've dropped of the block but i think i'm getting it back tues days then i have to assemble it. Is your motor already built? and if so have you tuned it id like to know a realistic expectation to hp and tq specs, i was thinking of tossing a 250 shot on there but rich told me 100-150 would be the "safe" limit to go if i was dead set on the biggest spray jets.
