My 86 GP starts all the time. If on the same day as it's been driven, turn the key and it has the best idle of any G-body with a V8 I've had (three before this one). Sure doesn't like to sit. After a couple days you have to do the Ivan Pumpski and in seven seconds it'll be running, but rough like a top fuel dragster. I checked the choke. It doesn't close all the way when set. It's open about a quarter inch, there's a little slop on the link that goes up and down and attaches to the plate swivel. But, the choke opens up nicely after a few minutes. Still, it idles pretty rough for a little while. If you try to stick it in gear and go, it'll die. But within a few minutes it'll start idling nearly perfectly. And, not gradually but all of a sudden. I just wish I could hear it coming and figure out what the hell is making it do that. If it just snaps into perfect idle mode like that, shouldn't it do that automatically a lot sooner when it's cold? Or, is this just normal behavior on a cold start for an electronic Q-Jet?
I'm not familiar with all the electronic gadgets on the carb and associated with it. Every stinkin vacuum line is new, but none of the control modules or anything else with a wire coming out of it on the carb. I should mention there is no cat. There's dual pipes going from the manifolds back, so I can imagine it won't idle like new but when warmed up it's ideal. The AIR pump is there, still has lines going to the manifolds. After it idles nice, it's got good response. No hesitation or carb burping or missing. I don't even think it's worth doing plugs it runs so well. I floor it on the entrance ramp and the sound reminds me of Bo and Luke.
Any ideas? Total carb rebuild time? One of the electro-gadgets? Forget it and be happy it runs nice after warmed up and get a case of Molson?
