Hey, being an Old Head ain't a bad thing, but I like wordplay and if it gets clicks, well, WINNING! I like to think of myself as being one to a hefty degree as well. Plus I'm willing to bet that nobody here under 50 knows a thing about these cylinder heads anyway, thus my need for "Old Heads" to chime in. You've been inside a few smallblocks, any pearls of wisdom you could share or thoughts to discuss? All opinions are welcome and appreciated.
I kind of figured I'd be happiest with 54 or 58 cc and 1.84 intakes but it looks like I've got 1.72s. Without cc'ing the things I don't know if they're 54, 58, or 60 cc chambers, or what the intake port volume is since online reports vary. I'm open to using steel shim gaskets or the thicker ones to achieve proper quench or compression. The internet is full of experts with misinformation as well as typos, and I definitely trust you guys more than them. I also lack any knowledge about which has the best designed ports, ramps, runners, chamber entry, and such. For instance, between the 416, 601, and 525 Vortec there are a few differences I care about but each has its place. The 601 has a better chamber and intake runner as cast but with porting the 416 can be better from everything I've seen and read. I'm still learning and have a long way to go, and have forgotten more than I want to admit. I have no "pie in the sky" dreams for this, but would like to make the best of what I've got at hand. That "dream" for the 305 would be an M90 on a custom manifold feeding some 76 cc 882s with Manley valves and possibly a stroker crank. The heads are on the El Camino, I have no blower, and would have to make the manifold for it. Realistically, I can drop any of these heads on fairly quickly and notice a marked improvement over what I have, and don't need to blow much $$ since the engine has had an issue or two already. If it blows up, it blows up- then the 350 gets swapped over.
Naturally aspirated, yes. A small shot would hopefully be fine with 114° lobe separation and can stay in the car for the next engine. I know the cast pistons and other factory bottom end parts wouldn't like it much though. I don't currently have a setup, nor a strong desire to hook one up in the immediate future either.
