Thank you for that info!That is your Manifold Absolute Pressure, or MAP for short. Should have only 1 vacuum hose to it, and the wiring you see there. Your ECM needs this. Part of the computer system to control emissions properly.
I think it's the same but mine is just dirty. I will clean it up a bit and take a better photo to determine if it's the correct emblem.FYI- although it's a tad hard to tell, I believe you have an incorrect year "Oldsmobile" emblem on your trunklid under your 442 decal. I'm guessing it's either a newer year than 88 or from a different model. If you need one, I have NOS ones for $35 plus shipping. Not a Chinesium knock off.
Should be a bit more raised in appearance, although not quite as pronounced as the front bumper emblem. GM p/n 20000969. It has the open leg "m" in the center.
Should look more like this when installed:
Agreed. It could just be the angle of the picture. It's just a little pet peeve of mine to see people just slap any old thing on a car to "restore" it without doing any research or listening to "experts" who are anything but experts. Not saying you did anything, because you just recently bought the car.I think it's the same but mine is just dirty. I will clean it up a bit and take a better photo to determine if it's the correct emblem.
How does it go on?FYI- although it's a tad hard to tell, I believe you have an incorrect year "Oldsmobile" emblem on your trunklid under your 442 decal. I'm guessing it's either a newer year than 88 or from a different model. If you need one, I have NOS ones for $35 plus shipping. Not a Chinesium knock off.
Thank you...that was helpful.That is your Manifold Absolute Pressure, or MAP for short. Should have only 1 vacuum hose to it, and the wiring you see there. Your ECM needs this. Part of the computer system to control emissions properly.
Like the decals, it's peel and stick. From the pictures, it is the correct emblem, and it appears to be in the correct spot. However, it's very weathered (plus you may want to check that area between the back window and trunk- it appears to be a bit rusty in front of the trunklid gasket in that area). There's about 3/16" to 1/4" gap between the bottom of the 442 decal and the emblem.How does it go on?
