Hi...
I'm new here and could use some help... I have a '79 Cutlass with a 403 Olds an a stock '86 442. I bought the 442 in May of 1994 with 15k miles on it. It now has around 70k on it.
The 442 has always had a front wheel shake on the pass side since day one. It starts around 65 mph or so and never goes away (at least up until 90mph or so...) I guess I always tolerated it but now I have to fix it... It shakes so bad that I put a piece of foam between the pass. side visor because the vanity mirror kept rattling against the plastic headliner (its a T Top car...) And then a few summers ago a belt actually broke in the pass front tire. I thought one of the factory 15x7 rims was bent so I bought another one (a new one from Specialty Wheel) and put a new tire on it. The shake is still there.
Has anyone experienced anything similar to this? The shocks (KYB's) appear to be good, the ball joints and tie rods are tight, etc. The wheel bearings where a little loose so I tightened them up slightly last night with no luck. It does pull to the right so I am going to have it lined up this week. Maybe a rotor out of balance? The factory rotor on the driver side has a weight between two of the fins while there is none on the pass side.
Any help would be appreciated!
Thanks,
Tom
Thanks,
Tom
