86' Cutlass Supreme
If you have a 307 in your Cutlass,the easiest option would be a 350 or a 403 Olds motor.Ignore the 350 Chevy.
To begin with, swapping a 350 or 403 Olds engine in place of your 307 is very easy, because ALL small-block Olds engines(260-307-330-403) share the same block dimensions, in other words they are all the same size. They all share the same bellhousing pattern,and in fact most everything in this engine family is the same as far as mounting locations, water outlets and things of that nature.As a rule all accessories bolt in the factory locations, and with a little attention to detail and some black paint, a 403 can easily masquarade as a weak 307.
This swap amounts to buying or building a 350/403, and simply drop it in. Things such as starters, flywheels, carburetors, exhaust manifolds and accessories swap directly over, or you can just use the 350 pieces.
You do not want to use any 307 heads on a 350/403. You can use 307 intakes and exhaust manifolds on a 350/403 provided that they are the 1980-84 versions with normal sized ports. Otherwise the later 307 pieces will restrict the engine unduly.If you are using the factory computer-controlled Qjet from the 307, at the very least you need to modify the secondary airdoors to open fully, and preferable rejet it to match the larger engine.
NOTE:
As with anything, there are exceptions. This is an overview of the swap, and not every detail has been explained. This does NOT apply to the installation of Chevrolet smallblock in place of an Olds engine. There are several differences including a different bellhousing pattern which dictates the use of a chevy transmission, and is generally discouraged.
This also does not address emission requirements, so it will be up to you to get through emissions testing.
400-425-455:
The big-block Olds in basically a taller deck version of the smallblock Olds, so it is nearly as easy to swap in as a SBO. However, the engine is wider, so in most cases headers are a difficult proposition. Otherwise, with a little patience this engine can be dropped into your 307 car with little effort.
Transmissions:
Since all Oldsmobile V8s share the same bellhousing pattern, any transmission that fit a 307 will fit the other engines. However, if the transmission in question is a metric 200, it's lifespan might be measured in hundreds of miles. In most cases, a 350 or larger engine used a transmission that was capable of handling the increased power, so try to buy them as a pair.
231 to a V8:
This is a popular swap also. There is more involved here, but it amounts to removing the V6 and acquiring some V8-specific items before installing the V8.
These include radiator, fan shroud, engine mounts and frame mounts(you CANNOT use the V6 frame mounts because they will sit the V8 too high). The V6 fuel line from the tank exits on the opposite side from the V8, you will have to run line over to the other side in a safe manner. The charcoal canister and battery swap sides when going to the V8.
There are some wiring issues that have to be addressed, but it mainly involves rerouting the wires for the sending units and the distributor.
The very best place to find the needed swap parts is from a junkyard G-body Olds.
__________________
swaps
so your saying i can use most of my engine parts on the 350 minus the heads, intake, and manifolds. i am planning to change these three things plus a couple of other things on the engine as well.
^^ Only if you keep a olds motor. I have a 71 Olds 350 in my 87 cutlass. Take the old out throw the new in, but you want to keep the pulley system the same. Keep what came on the motor or take the whole system off you 307. Also use the 307 motor mounts. If you throw a chevy in you have to do alot of tweaking.
the old's rocket 350 is a really good engine. my friend has one in his 88 cutlass. i think it is kinda cool because its a olds motor in a olds. the only downside is the price to build them up vs a sbc.
i think you REALLY need to do some research. research researchr esearch!! it is the best thing you can do, do NOT jump into a engine swap untill you are comfortable and confident that you can do it. your first swap will be a hell of a experiance but it can also be a nightmare, mine was. a good tip i learned on mine was that the clam shell motor mount that you will use comes in 2 styles, 1 for cars and 1 for trucks. guess which clam shells i got on my first swap, yea, i could not figure out why the engine was sitting too high and nothing lined up lol
My first experience with swapping an engine was converting a 1978 Oldsmobile Delta-88 from a Diesel 350 to an SBC 350. Talk about a nightmare!
I agree, though... nothing beats research. The web is an invaluable source -- the good thing about these cars is that lots of people work on them and there are a ton of sites dedicated to doing this or that. Plan out everything in advance and get ready for things to go wrong... because they will.
im a hardcore Olds guy, i would have just went with a gas 350 but a lot of people run Chevy engines...did you end up swapping the trans too? or did you get an adapter plate? O BTW that diesel engine is sought for its super strong block...hold on to it, itll be worth some cash
We replaced everything, from the engine back. New trans, drive shaft, differential... I think we pulled it out of an old Caprice. It was a mess. And then the best part is that like six months after we put it in, a freeze plug blew out while my mom was driving and killed the engine... which paved the way for a 403, which, again, needed a new trans. Yeaargh.
