I have the replacement Upper Control Arm with the Ball Joint included..Please help, I have run into 2 problems:
1) I can't get the pivot shaft loose from the frame bolts on the Upper Control Arm to break it free..Looking at the new one, I see that the shaft doesn't have threads in the holes, so it can't be bolted in. I've tried to bang/ pry it loose..Any suggestions?
2) The old Ball Joint is stuck, is there any way to get it out without using the Ball Joint removal tool?
Thanks in Advance!
Thanks in Advance!
