86 Monte Ss Click, click, click. When you turn the key. Definitely starter? Or no?
Alex Benigno
14
2
When you turn the key you get one click. Sounds like anew electrical problem any suggestions?? Thanks
ssn696
Living in the Past
5,561
6,730
Permanent Temporary
OK, 'splain something. Tim - Alex - related? Same person, multiple personalities? Not a common name like Smith...
ssn696
Living in the Past
5,561
6,730
Permanent Temporary
Check the battery cables - do you have a solid ground, not crusty? If all is well, can you reach down and rotate the engine by twisting the crank pulley? Starters die, too.
Alex Benigno
14
2
Does your battery have enough juice? Maybe get it checked?
If your starter is going or gone you can try to give it a couple of whacks with a hammer. Don't go crazy. Just enough to try and loosen the contacts.
Tried it, made a different type of click, still no luck definitely the starter
Alex Benigno
14
2
Didn't try
Didn't try twisting the crank pulley, we were stuck in the rain. Will try tomorrow!
ssn696
Living in the Past
5,561
6,730
Permanent Temporary
Do you have about 12.6 volts on the battery terminals? If less, the battery is discharged. Also, if it has removable vent covers, check the water level. If the tops of the lead plates get to air, that kills a battery off pretty quick. If a discharged battery gets cold enough that the water and acid start to separate, that's also death.
Alex Benigno
14
2
We didn't have our multimeter, but assumed it's either a bad battery or starter, or even worse... both! Will know tomorrow
ssn696
Living in the Past
5,561
6,730
Permanent Temporary
Just making sure the engine didn't seize...focus on the more likely things first.
If by chance you belong to Costco, they have remarkable prices on their car batteries - made by Interstate, I think.
