86 Pontiac 2+2
rsucanick
n00b
Aug 7, 2012
I am restoring my Pontiac 2+2 and I am searching for a complete floor council, front upper and lower passanger side grills, stock ralley rims, both door window seals. do you have any hook ups to these items
Sure hope you put a stick in it never seen or heard of one
When I bought my 2nd 2+2, the owner had his good 2+2 there with a stick in it.
Here is some cool ideas and links; http://www.performanceplustire.com/prod ... ctID/14160 I would do a 15x7 & 15x8 and or look at a 16x7 & 16x8 relatively cheap so that you have the option of doing big brakes & better control arms etc as well as more modern tires. In 17s there is also https://www.yearone.com/Product/DisplayProduct/403547
LOL Here is a big bad arse Pontiac street engine. http://www.jbp-pontiac.com/FeaturedEngi ... Street.htm They have other big bad pump gas Pontiacs for less built from an original factory Pontiac block. Naturally that would take a 4l80E & controler. http://extremeautomatics.com/transmissions/4l80e.html and a controler at Jegs sells for $700. Butler & Extreme are just examples there are many other companys that provide these.
If you are not Pontiac die hard I kind of like this idea LS to Gbody conversion parts including headers are now on the shelf different places. Plus you can build your trans to handle it and not need a computer controller for it. http://www.jegs.com/i/Chevrolet-Perform ... oreDetails
Here is what is takes to have your trans rebuilt with warranty; http://extremeautomatics.com/transmissions/2004r.html
Again Jegs & Extreme are examples.
