Picked up the SS and made the 3 1/2 hour drive home.
-idles at 750 in gear when warmed u, 950 in neutral
-coolant temp is slightly on the cold side (it's metric, needle only moves 1/3)
-speedo twitches occasionally when going up to speed
-volts gauge ready slightly low, twitches with 4 ways on
-engine fan is noisy during acceleration also slight pinging
so far I have
-tightened carb bolts/torx screws
-checked for vaccum leaks
-shimmed lower drivers side hinge - hinge bushings have no play but door was hanging low at striker
(also striker mounting metal has slight cracking = probably from supporting door)
-lube hinges, door latches
-treated rubber seals and dried exterior striping with Aerospace 303
-auto adjusted the drum brakes
The dash is grey/blue- ish and has 0 cracking - any tips to keep it that way???
Need to remember to set the choke on cold starts
This car does what GM did best---great shifting auto trans and comfortable highway(freeways to you Americans) driving experience in a stylish vehicle
so far I have
