This is a very simple and probably nowhere near complete (or accurate) budget I have put together for my project. I have broken in up into "stages", if you will, to spread out the cost. I plan on doing the engine and trans together. Once they are complete at least I can drive it again, and by upgrading the wheels, tires and suspension (read traction) I should ok with the stock rear end for a while. Feel free to comment. Are there any glaring holes?
Engine | Trans | Rear end | ||||||||
Engine 6.0 LQ4 | $750.00 | Transmission | $500.00 | Rear end housing | $250.00 | Wheels | $1,200.00 | |||
fitech ultimate ls | $2,450.00 | Shift kit | $200.00 | Posi | $500.00 | Tires | $1,000.00 | |||
cam BTR N/A stage 3 | $400.00 | Crossmember | $150.00 | Gears | $250.00 | line lock | $125.00 | |||
Heads 706 w/ valve job | $400.00 | Converter | $300.00 | |||||||
valve springs | $200.00 | Shifter | $300.00 | Ready to go G-body | ||||||
Lifters upgrade | $100.00 | Cooler | $100.00 | rear w/posi & gears | ||||||
lifter trays | $50.00 | usually go for between | ||||||||
oil pump | $145.00 | $800.00 - $1200.00 | ||||||||
engine mounts | $100.00 | |||||||||
headers | $270.00 | |||||||||
Air intake | $75.00 | |||||||||
Mufflers | $70.00 | |||||||||
Exhaust | $150.00 | |||||||||
Rockers | $175.00 | |||||||||
Total | $5,335.00 | Total | $1,550.00 | Total | $1,000.00 | Total | $2,325.00 |
