SS monte 87 tryna figure out what exactly I need to do to throw some 24" irocs on it not really tryna do cups any suggestions or tips or anything let me know please and thank you
See I'm tryna see exactly what I need and I ain't tryna cut on my fenders u saying new springs and shocks for a what year 87?? I wanna sit up a lil bit just just not to high ..n not tryna deal with no rubbing so I don't know about the 275 tiresQdub24 said:The correct backspacing/offset on the rims, and brand new V8 Monte Carlo springs and shocks. Make sure that you use 275/25/24 tires.
How u got that cutt liftedQdub24 said:That's the skinniest 24" tire they make. You could try a 255/30/24, but you'll be sitting higher and may need a little lift. Brand new, stock replacement springs and shocks should be all that you need for 24s. The correct backspacing/offset is the most important factor to get your stance right, and eliminate the possibility of having to use spacers. If everything is good, you should only experience rubbing when turning the wheel hard, ie. lock to lock.
And u cleared 6s like thatQdub24 said:No lift at all. I don't like lift kits. In my sig pic it had brand new, heavy duty, '72 Impala w/big block springs and shocks from Autozone. The rear has the OE, worn out, '83 Cutlass w/V6 springs and shocks from 1983.
Where you get trailing arms everybody tell me that's a must on gbodys unless you do a lot of cuttingQdub24 said:In the front yeah. You have to get extended/adjustable trailing arms for the rear.
