Not sure if I should ask this in the Olds forum or not, but I have an 87 Regal with the Olds 307 which I havnt been able to start. I thought for sure it was ignition related until today. I unscrewed the filter and line from the front of the carb, and a small amount of fuel spilled out. But when I pumped the pedal NO gas was coming out of the line. It has a mechanical pump, I even turned the ignition on in case there was some electric relay controlling the pick up or pump I dont know about and nothing. Shouldnt I be getting fuel when pumping the pedal? I think the pump or pick up went? Or a block in the screen or gas line? Thanks...
