87MCSS original muffler hanger needed
chriscris
11
Campbellville, Ontario
My original muffler hangers had been butchered years ago, so I dont know what they should look like.
I am going fully stock with exhaust.
Just curious if anyone has any pictures of a stock set.
Thanks very much
Chris
8,185
17,561
GM part numbers for the hanger with rubber bits.
14065790 (1st design, 84)
14081994 (2nd design, 85-88). This one is what you seek, although maybe the 84 would work?
There's also the rear tailpipe brackets too.
GM part number 14065797 . Need 2.
Some on ebay. PRICEY though.
However, Walker makes some too. Or did.
tailpipe bracket is walker part 35125. Looks a bit different than the orignal circle clamps.
hanger is just rubber and bolt kit, walker p/n 36261 for 85-88. The 84 version is walker p/n 35209. Same on either side.
35125
https://www.amazon.com/dp/B000CQBG14/?tag=gbody-20
35209 (1st design hanger)
https://www.amazon.com/dp/B000C8ZAMS/?tag=gbody-20
Walker 35261
partImageDisplay.do
8,185
17,561
Oh, and the bracket those tailpipe hangers would go to are GM p/n's 14089527 and 14089528, different for either side
cat hanger is 14065787.
Good luck with finding GM stuff. The latest stuff was discontinued from GM 20 years ago.
79 USA 1
1,063
2,036
Cheektowaga, New York
Chris,
These are shots from under my 88 Monte Carlo SS. Due to running a 2.5 cat back system I ended up welding the brackets to the pipes. The bracket behind the muffler was made for 2.0 pipe and the ring that wrapped the tail pipe at the bumper was made for 2.25 pipe.
Left side at muffler and Right side at muffler.
These are the tail pipe factory hanger without the strap.
Left and Right.
I have in the past used for my 86 El Camino universal hangers attached at the rear bumper/frame bolts and a 1.0 wide steel strap to support the pipe at the rear similar to the factory bracket.
ostrich
310
313
Ontario, Canada
35125
Walker 35261
partImageDisplay.do
Chriscris, if you're looking for a pair of the Tailpipe hangers (those ones on eBAY) let me know I have a pair left over from my build.
