Hi all, some of you might remember me from previous forms from when the car was having trouble starting and was stalling out. Iv gotten many good answers and I'm still referring to the excellent info iv received from there for this current problem. Iv since resolved that by replacing the fuel pump. The car was fine for about 6 months and now I'm having trouble again. Its not stalling and has no trouble starting and cruises fine, however, its still generally boggy when going down the road and hesitates when you accelerate suddenly from a stand still or when you try to accelerate quickly when rolling. Another words, when your maintaining speed, its fine, but when you hit the gas from a stop, it will bog out and you have to either get off the gas and hit it again more gradually, or sometimes at higher speeds you have to mash it to get out of the bog cycle, sounds like a classic accelerator pump issue, except that was replaced 6 months ago.
List of things that have been replaced/checked
-Fuel Pump Replaced
-Carb professionally rebuilt two years ago, then professionally cleaned and had the accelerator pump and filter replaced 6 months ago
-Vacuum lines professionally checked and passed 2 days ago
-Timing on point (Mechanic checked 2 days ago)
-Idle is good (also Mechanic checked 2 days ago)
-New spark plugs/wires/ignition coil/module 2 years ago
-Fluids all changed 2 years ago
-Kickdown cable and throttle all replaced and tuned professionally
-Gas tank lines replaced
-New Battery
-Valve cover gaskets replaced
-Electric wires and plugs for electronic choke replaced
-Pretty much any preventive maintenance/old car maintenance/and broken parts have all been replaced
-Rest of the car is in amazing shape, very solid, and has 0 issues other then that damn buick 3.8
It was at the mechanic 2 days ago, where he played with the timing and checked all the lines/carb/etc, and it only made the bogging more tolerable, not a permanent fix. Many of you will probably say that I had a crappy mechanic, and while I do agree to some extent, he is known to be one of the best mechanics in my area. The mechanic before him I took it to for the fuel pump issue always gets it right, though he's had it twice and his work has never lasted more then a year. Again, it could be the mechanics, but these guys are some of the best around and typically deal with cars like this and always have good reviews. I'm at my wits end with this thing, whether I get rid of it or not, I would like to get it fixed so I can either be able to get to work or be able to sell it for enough money to get another problemed car. I could try to get a good driving video from the hood to hear the engine if that would be of help to anyone.
-Fuel Pump Replaced
-New Battery
