A/C Hose Insulation
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,997
Socialist NY
Do they make lengths of the foam insulation that goes over some parts of the A/C lines?
Thanks!
I posted this a while ago, and got nothing. So, I bought some pipe insulation from Home Depot. Then, my compressor locked up.
I also brainfvcked it to death and came to this conclusion: the orifice tube is so close to the core in the heaterbox, it's unnecessary.
I'm assuming G-body here, but the idea is that the insulation keeps warm air off the colder compressor suction line going back to the compressor and hotter, compressed gas going from the compressor to the condenser. The evaporator isn't 100% efficient in absorbing all the heat from the air passing over it, so humidity in the air may condense on the suction line. It's more of sweat control than anything else on the suction line. Don't want water dripping all over the hot engine/exhaust all the time. Depends on relative humidity around that suction line and if the system is operating correctly. The compressor discharge line insulation is for heat/burn protection but it's positioned lower so it's tough to get burned there. But they did it anyway.
When I redid my 84 hoses, I went to an industrial hose shop to get them made because at the time, NOS ones were hard to find and it was actually a lot cheaper to have them made reusing my old hose ends. They installed new black foam sleeves over the hoses that looked like it belonged there. Since the insulation was one piece, the hoses couldn't be connected prior to putting the insulation on. I suppose you could slit and glue the insulation around the hoses if they're still made up to the system.
Some of the industrial supply companies carry the stuff. Check with some local A/C shops or hydraulic hose shop. They may have stuff you've never heard of.
Yes I checked with the shops here like Morland Hose They make up the lines but don't have the insulation for them.
Try a home HVAC supply house or ask the A/C service company if they can help you out. Their A/C line kits come with all sorts of insulation options, etc.
Reactions: TURNA
WOOOOOOOOO HOOOOOOOOOO
I don't believe it ...Of all places Home Dopey sells it!!
I'm in Home Dopey picking up some stuff say what the hell let me look down the plumbing isle.
There is it.....WTF!!!!!!!!!!
6 buxx for a 6 foot length!!!!
Get some electrical tape or something to hold it on with. That adhesive is probably ok for your stationary relatively constant temperature water or A/C pipes at home, but on your car....the split stuff's probably not going to last a long time.
For 6 buxx i will take the chance!!
