Two questions:
My A/C currently doesn't work. The compressor is hard and rough to turn. Maybe a bad bearing. Are these things repairable with common tools or do I need special pullers, etc? Are junk yard A/C compressors worth messing with? There are plenty of those to be had. There is one junkyard that offers a $4 warranty on parts so maybe that is an option? What are your thoughts?
Next, what do I need to convert to R134a? I bought a vacuum pump and guage set from harbor freight so I have that part now. I know I need to change some seals and parts but not sure which ones. I looked on some websites but the information varies.
First thing I want to do is try to pull a vacuum on the systems and see if it leaks. There is currently no freon in the system. Hopefully it leaked out through the bad compressor and not from the condensor or somewhere else.
