A Few Quick Questions
kingcolbert83
807
2
Do the 78 buick regals already have the holes for a buick motor? I'm not sure if the motor thats in my car came with the chevy motor or if somebody put it in there. but im thinking it did come from the factory with the chevy. Just trying to figure out if I get some buick frame pads will I have to drill new holes.
Also is there any difference between a bop th350 short tail and a chevy th350 short tail besides the bell housing?
It should have the holes needed, but i couldn't tell ya which ones. And as far as lenght goes the trannys should be the same.
ok thanks. also do you know where to get the hood bump stops from? the ones under the hood that keep it level. Looking for some new ones or reproduction.
You might be able to get them in the "help" section at you parts store. Can't remeber for sure though.
Look up the vin code for your car and the 8th digit will tell you what engine your car came from the factory. I don't know what they are off hand but it will be listed in the vin.
Yes, the frame are of a corporate design and will have multiple engine mounting holes.
