After posting a request for crossmember dimensions and getting nothing, I built one today,but, before I cut it again to build in the exhaust passages someone please help me! I centered the output shaft in the chassis, I assume thats right? and taking measurements from a stock th200 xmember to calculate height of the mount,when everything is bolted tight the centerline of the output shaft is slightly higher than the top of the frame rails? I would be more sure of myself if the body were on the chassis. I just swapped in a 454 and 700r4 in place of a 305 and th200,in an elCamino, in case any of those facts matter? Really, anyone who has a body off chassis with the engine and trans still in who could measure the height of the output shaft,in relation to the frame rails, I would REALLY appreciate it. I dont want to keep moving along with the next steps to find out later (like when the body goes back on) i really screwed up.Thanks
